Perform this procedure to enable Auto-sense on one or more ports.
If you select more than one port, the format of the tab changes to a table-based
tab.
- After a switch boots without a configuration file, Auto-sense is enabled on all
ports, by default.
- Auto-sense is disabled by default for existing configurations but enabled for new
Zero Touch Fabric Configuration deployments.
- Auto-Sense cannot be enabled when the spbm-config-mode flag is false.
You can also complete this task on the tab. For more information, see View or Modify the Auto-sense Port Configuration.
In the Device
Physical View tab, select one or more ports.
In the navigation pane, expand
Select General.
Select the Interface tab.
For AutoSense, select
enable.
Select Apply.
